July 19, 200817 yr Right iv got a Dep pipe on order and im thinking of upping the jet size but the only thing is im not sure what size to go/try. Any help would help and also where i could get some from. Thanks in advance,
July 20, 200817 yr Dont know the make of carb on the DT but you could try these http://www.nrp-carbs.co.uk/index.htm As for jet sizes i think its just trial and error.
July 20, 200817 yr Hi Ryan, usually if your carb needs to be rejetted the manufacturer of the pipe will tell you and recommened what size jet to put in ! But on most occasions unless your also changing your filter like putting on a K&N you don't need to? but as a general rule you should up your main jet by 10% then it's just trail/ error and adjustment to get it running properly Hope this helps you Regards Bill
July 23, 200817 yr Right iv got a Dep pipe on order and im thinking of upping the jet size but the only thing is im not sure what size to go/try. Any help would help and also where i could get some from. Thanks in advance, Iv got fhe DTR E125 06 i put a dep system on my bike a few weeks ago and if i were you i would leave the jets my bike runs great with the dep pipe on and the standard jets in.
