Here's a very simple question...what amperage main fuse should be on this bike? Currently (oops, bad pun), there is a blown 6A installed. The Clymer does not indicate what size it should be (although that info could be in an obscure table somewhere). Anybody?
1 (1M1-82590-21-00) WIRE HARNESS ASSEMBLY . . 1
(1M2-82590-21-00) WIRE HARNESS ASSEMBLY . . 1
2 443-82508-21-00 MAIN SWITCH ASSEMBLY . . . 1
3 1M1-82555-00-00 DAMPER, MAIN SWCH 1 . . . . . 1
4 1M1-82556-00-00 DAMPER, STOPPER . . . . . . . . 2
5 90201-05033-00 WASHER, PLATE . . . . . . . . . . . 2
6 92990-05100-00 WASHER, SPRING . . . . . . . . . . 2
7 98503-05025-00 SCREW, PAN HEAD
(98501-05025) . . . . . . . . . . . . . 2
8 260-83371-12-00 HORN . . . . . . . . . . . . . . . . . . . 1
9 97013-06012-00 BOLT . . . . . . . . . . . . . . . . . . . . 2
10 92995-06100-00 WASHER, SPRING . . . . . . . . . . 2
11 92901-06600-00 WASHER . . . . . . . . . . . . . . . . . 2
12 1Y8-82310-40-00 IGNITION COIL ASSEMBLY . . . 1
13 98511-06025-00 SCREW PAN HEAD
(92501-06025) . . . . . . . . . . . . . 2
14 92995-06100-00 WASHER, SPRING . . . . . . . . . . 2
15 90462-05005-00 CLAMP . . . . . . . . . . . . . . . . . . 1
16 81E-82370-20-00 PLUG CAP ASSEMBLY . . . . . . 1
17 1M1-82530-02-00 STOP SWITCH ASSEMBLY . . . 1
18 BTY-6N63B-10-00 YUASA 6N6-3B-1
(1E6-82110-29) . . . . . . . . . . . . . 1
19 90445-08047-00 HOSE (168-82112-00) . . . . . . . . 1
20 118-82141-09-00 LABEL, BATTERY . . . . . . . . . . 1
21 120-82131-00-00 BAND, BATTERY . . . . . . . . . . . 1
22 1E6-82122-01-00 SEAT, BATTERY . . . . . . . . . . . 1
23 1M1-82115-00-00 WIRE, PLUS LEAD . . . . . . . . . . 1
24 1E6-82150-00-00 FUSE HOLDER ASSEMBLY . . . 1
25 1E6-82151-00-00 FUSE (10A) . . . . . . . . . . . . . . . 2
26 1M1-83350-60-00 FLASHER RELAY ASSEMBLY . 1
CONTINUED ON NEXT FRAME ä
ELECTRICAL
Ref. Part
No. Number Description Qty Remarks
E9 DT250D_DT400D
ELECTRICAL
Ref. Part
E9 DT250D_DT400D
Thanks, O G...where did you get this parts list?
