DT 175 Gas Leak HELP!!!
This post is 5901 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
just bought a 1978 yamaha dt175 and seems to run fine. However everytime i stop runnin it, tons of gas pours out of the overflow tube hanging from the carb. How do i fix this?
Its likely to be the carburetor float height setting, it should be set to 21mm
Link to comment
Share on other sites
  • 2 months later...
Thanks I have the same problem. I'm waiting for a manual for the bike. The float height is 21mm, how is this measured? With the float hanging down or with the needle just touching the float?
Measure wit the float just touching the needle and measure to the carb flange, not the gasket that sits thereon
Link to comment
  • Recently Browsing
