engine oil fzr
well the question has been on here 5 day's and it seems none of you have any opinions or answers for the best engine oil to use in my fzr. THANKS FOR THE HELP !
hi m8
i use castrol active evo about 25 quid for 4 ltr never had a prob,,,,,,,,,,,,,,,,,,,,
Look in the bikes handbook and it with magic will tell you.
ive used motul for years mate but i think its realy down to personal prefferance as long as the oils spec matches ya bike's spec!
Hi is that why your called yoda for the smart replys! if I had the hand book I wouldn't be asking. thanks for the help mad73 and stonsie.
Ive looked in the 'haynes manual ' it says coorect oil is
oil type API grade SE or SF (minimum)
oil viscosity below 15C (60F) SAE 10W30
above 5C (40F) SAE 20W40
capacity(without oil cooler) with filter change 3.0 liters
oil change only 2.7 liters
oil drainplug torque spec 43 Nm (31 ft lbs)
oil filter bolt-cartridge type 15Nm (11 ft lbs)
spin on type 17 Nm (12.5 ft lbs)
hope this might help mate
hi stonesie, thanks for that at least I know quality and quantity to use now. better info than some I could mention.
Thanks Again
