July 19, 200817 yr Author well the question has been on here 5 day's and it seems none of you have any opinions or answers for the best engine oil to use in my fzr. THANKS FOR THE HELP !
July 20, 200817 yr hi m8 i use castrol active evo about 25 quid for 4 ltr never had a prob,,,,,,,,,,,,,,,,,,,,
July 20, 200817 yr well the question has been on here 5 day's and it seems none of you have any opinions or answers for the best engine oil to use in my fzr. THANKS FOR THE HELP ! Look in the bikes handbook and it with magic will tell you.
July 20, 200817 yr well the question has been on here 5 day's and it seems none of you have any opinions or answers for the best engine oil to use in my fzr. THANKS FOR THE HELP ! ive used motul for years mate but i think its realy down to personal prefferance as long as the oils spec matches ya bike's spec!
July 21, 200817 yr Author Hi is that why your called yoda for the smart replys! if I had the hand book I wouldn't be asking. thanks for the help mad73 and stonsie.
July 21, 200817 yr Hi is that why your called yoda for the smart replys! if I had the hand book I wouldn't be asking. thanks for the help mad73 and stonsie. Ive looked in the 'haynes manual ' it says coorect oil is oil type API grade SE or SF (minimum) oil viscosity below 15C (60F) SAE 10W30 above 5C (40F) SAE 20W40 capacity(without oil cooler) with filter change 3.0 liters oil change only 2.7 liters oil drainplug torque spec 43 Nm (31 ft lbs) oil filter bolt-cartridge type 15Nm (11 ft lbs) spin on type 17 Nm (12.5 ft lbs) hope this might help mate
July 21, 200817 yr Author hi stonesie, thanks for that at least I know quality and quantity to use now. better info than some I could mention. Thanks Again
