Posted July 14, 200816 yr Hi, Does anyone have a good set up for a YZF750R, MCN did a booklet a few years back which I've unfortunately lost which had this in. Any help gratefully accepted. Cheers
July 14, 200816 yr Hi, Does anyone have a good set up for a YZF750R, MCN did a booklet a few years back which I've unfortunately lost which had this in. Any help gratefully accepted. Cheers i have that book some where if i find il let u no ,,,,,,,,,,,,,,
July 18, 200816 yr ok found the book so here we go. rear shock pre load 16.5 mm thread between top of locking ring and under side of shock top, rebound 7 clicks out from full in,,compression 5 clicks out froks preload 2 and half lines showing (8mm)from top of preload nut to the top of fork cap rebound 2 clicks out from full in compression 3 clicks out hope this helps but i would think that it would all go on your wait ,, i had these settings on my yzf and it was much better and im about 11 and half stone ............................
July 18, 200816 yr Cheers for that, I'll start with those settings and see how it goes no probs m8 i have std settings as well if u need to change back,,,,,,,,,,,,,,,,,,
