YZF750R Track set up
Hi,
Does anyone have a good set up for a YZF750R, MCN did a booklet a few years back which I've unfortunately lost which had this in.
Any help gratefully accepted.
Cheers
Hi,
Cheers
i have that book some where if i find il let u no ,,,,,,,,,,,,,,
ok found the book so here we go.
rear shock pre load 16.5 mm thread between top of locking ring and under side of shock top, rebound 7 clicks out from full in,,compression 5 clicks out
froks preload 2 and half lines showing (8mm)from top of preload nut to the top of fork cap
rebound 2 clicks out from full in
compression 3 clicks out
hope this helps but i would think that it would all go on your wait ,, i had these settings on my yzf and it was much better and im about 11 and half stone ............................
Cheers for that, I'll start with those settings and see how it goes :thumb:
no probs m8 i have std settings as well if u need to change back,,,,,,,,,,,,,,,,,,
