DT125MX oil tank
Hi all!
I have just bought a DT125MX 1980 model. Its for my son to drive around the lanes down here in the South West of france (great trails here).
problem is i don't know much about bikes...can anyone tell me:
What is the plastic tank on the right hand side for that says Motor Oil ..... yes ok it's for oil but should it be kept full and with what oil?
2 Stoke mixture what should it be and do you just pre - mix and put the fuel in the tank?
What grade oil do you use for the engine, how much does it take and where is the sump plug?
Gear Box again what grade of oil and where is the drain plug and hole for adding the box oil?
I have also to replace the air filter what type / marque would be best for dusty trails?
thanks guys
