R1 2005 BHP
BERGY
This post is 5783 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Firstly a big hello to all from a new member,please can somebody tell me what BHP a standard 2005 R1 produces ?.Thank you
:welcome: to the forum matey. Heres your specs for said bike.....
Engine Type Horizontal In-line
Cylinders 4
Engine Stroke 4-Stroke
Horsepower (bhp/kW) 180 / 134.3 < BHP here
Horsepower RPM 12500
Cooling Liquid
Valves 20
Valves Per Cylinder 5
Valve Configuration DOHC
Bore (mm/in) 77 / 3.03
Stroke (mm/in) 53.6 / 2.11
Displacement (cc/ci) 998 / 60.9
Compression Ratio 12.3:1
Starter Electric
Battery Amp Hour 8
Fuel Requirements Regular
Ram Air Induction Yes
Fuel Type Gas
Fuel Injector Yes
Fuel Injector Size (mm) 40
Carburetor No
Carburetion Type Fuel Injected
Transmission:
Transmission Type Manual
Number Of Speeds 6
Overdrive No
Primary Drive (Rear Wheel) Chain
Gear Ratio (1/2/3/4/5/6) 2.533 / 2.063 / 1.762 / 1.522 / 1.364 / 1.269
Reverse No
Wheels & Tires:
Wheels Composition Aluminum
Tube / Tubeless Tubeless
Front Wheel Width (in) 3.5
Rear Wheel Width (in) 6
Chromed No
Tire Brand Dunlop®
Front Tire Width 120
Front Tire Aspect Ratio 70
Front Tire Speed Rating Z
Front Wheel Diameter 17
Rear Tire Width 190
Rear Tire Aspect Ratio 50
Rear Tire Speed Rating Z
Rear Wheel Diameter 17
Front Tire (Full Spec) Dunlop 120/70 ZR17
Rear Tire (Full Spec) Dunlop 190/50 ZR17
Brakes:
Front Brake Type Dual Disc
Front Brake Diameter (in/mm) 12.6 / 320
Front Caliper Pistons 4
Rear Brake Type Disc
Rear Brake Diameter (in/mm) 8.7 / 220
Rear Caliper Pistons 1
Suspension:
Front Suspension Type Inverted Fork
Front Suspension Size (in/mm) 1.7 / 43
Front Travel (in/mm) 4.7 / 119.4
Front Adjustable Fork Pre-Load Yes
Front Adjustable Rebound Damping Yes
Front Central Suspension Strut No
Rear Suspension Type Twin Sided Swing Arm
Rear Travel (in/mm) 5.1 / 129.5
Rear Adjustable Shock / Spring Pre-Load Yes
Rear Adjustable Rebound Damping Yes
Number Rear Shock Absorbers 1
Rear Suspension Material Aluminum
Air Adjustable No
Steering:
Steering Control Handlebar
Technical Specifications:
Length (in/mm) 81.3 / 2065
Width (in/mm) 28.3 / 718.8
Height (in/mm) 43.5 / 1104.9
Wheelbase (in/mm) 54.9 / 1394.5
Rake (degrees) 24
Trail (in/mm) 3.8 / 96.5
Turning Radius (ft) 12.8
Ground Clearance (in/mm) 5.5 / 140
Dry Weight (lbs/kg) 379 / 171.9
Wet Weight (lbs/kg) 426 / 193
Payload Capacity (lbs/kgs) 445 / 202
Fuel Capacity (gal/l) 4.9 / 18.4
Fuel Capacity Reserve (gal/l) 0.9 / 3.4
Redline RPM 15000
Engine Displacement to Weight (cc) 2.63
Horsepower To Weight (hp) 5.54
Seats:
Seat Type Two-Piece
Adjustable No
Seat Material Vinyl
Seat Location Driver and Passenger
Folding No
Seat Height (in/mm) 32.8 / 833.1
Number Of Seats 2
Grab Rail or Strap Standard
Exterior:
Frame Aluminum
Body Material Plastic
Hand Grip Material Rubber
Foot Peg Material Aluminum
Foot Peg Location Driver and Passenger
Adjustable No
Brake Rotor / Caliper Guard No
Chain Guard Yes
Drive Shaft Guard No
Fork Guards No
Saddle Bag Guard No
Belt Guard No
Hand Guards No
Brush Guard No
Exhaust Guard Yes
Light Guard No
Choke Knob Cover No
Drive Shaft Cover No
Swing Arm Cover No
Brake Caliper Cover No
Brake Disc Cover No
Carburetor Cover No
Front Fender Material Plastic
Rear Fender Material Plastic
Stand Type Kick
Lower Fairing Standard
Spoiler Standard
Handlebars Standard
Upper Fairing Standard
License Plate Standard
Instrumentation:
Digital Instrumentation Standard
Clock Standard
Tachometer Standard
Trip Odometer Standard
Lap Timer Standard
Shift Light Type Adjustable
Speedometer Standard
Temperature Warning Type Gauge
Fuel Level Warning Type Light
Pricing:
Warranty (Condition) Limited
Zero Price Schema 0
Identification:
Generic Type (Primary) Sport
Manufacturer Country Japan
Manufacturer Recommend Minimum Age 16
MIC Model Segment ON-HWY Sport Bike Over 750cc
Mounts:
Windshield Mounts Standard
Paint & Finish:
Metallic No
Glass:
Rearview Mirrors Standard
Windshield Lowers No
Height Adjustable No
Tinted No
Height Low
Storage:
Underseat Storage Standard
Lockable Storage Standard
Helmet Locks Standard
Lights:
Headlight Mounts Standard
Halogen Headlight (s) Standard
Convenience:
Handlebar Lock Standard
Hope that helps..... :blink:
Thats great thank you,i'm going to have it put on a dyno so its good to know what it should have to start with.
Bergy
If you put a standard bike on a dyno you will find that it produces about 15% less power than quoted. This is due to transmission losses and manufacturing tolerances.
We would all have cheaper insurance if the makers told the truth.
True enough :lol: so would i be right in thinking that factory quoted BHP is at the flywheel and not the back wheel ?
Thank you Bergy
Had mine on a dyno at CMC on there Dyno open day, got 149.10 BHP, 173 MPH at back wheel with standard cans de-baffled & a standard Y piece de-catted. bike ran a bit rich they told me to have a PC3 fitted & custom mapped to improve BHP & running. (must say it sounds wicked on over run with all the popping/banging)
