Posted July 10, 200817 yr Firstly a big hello to all from a new member,please can somebody tell me what BHP a standard 2005 R1 produces ?.Thank you
July 11, 200817 yr Firstly a big hello to all from a new member,please can somebody tell me what BHP a standard 2005 R1 produces ?.Thank you to the forum matey. Heres your specs for said bike..... Engine Type Horizontal In-line Cylinders 4 Engine Stroke 4-Stroke Horsepower (bhp/kW) 180 / 134.3 < BHP here Horsepower RPM 12500 Cooling Liquid Valves 20 Valves Per Cylinder 5 Valve Configuration DOHC Bore (mm/in) 77 / 3.03 Stroke (mm/in) 53.6 / 2.11 Displacement (cc/ci) 998 / 60.9 Compression Ratio 12.3:1 Starter Electric Battery Amp Hour 8 Fuel Requirements Regular Ram Air Induction Yes Fuel Type Gas Fuel Injector Yes Fuel Injector Size (mm) 40 Carburetor No Carburetion Type Fuel Injected Transmission: Transmission Type Manual Number Of Speeds 6 Overdrive No Primary Drive (Rear Wheel) Chain Gear Ratio (1/2/3/4/5/6) 2.533 / 2.063 / 1.762 / 1.522 / 1.364 / 1.269 Reverse No Wheels & Tires: Wheels Composition Aluminum Tube / Tubeless Tubeless Front Wheel Width (in) 3.5 Rear Wheel Width (in) 6 Chromed No Tire Brand Dunlop® Front Tire Width 120 Front Tire Aspect Ratio 70 Front Tire Speed Rating Z Front Wheel Diameter 17 Rear Tire Width 190 Rear Tire Aspect Ratio 50 Rear Tire Speed Rating Z Rear Wheel Diameter 17 Front Tire (Full Spec) Dunlop 120/70 ZR17 Rear Tire (Full Spec) Dunlop 190/50 ZR17 Brakes: Front Brake Type Dual Disc Front Brake Diameter (in/mm) 12.6 / 320 Front Caliper Pistons 4 Rear Brake Type Disc Rear Brake Diameter (in/mm) 8.7 / 220 Rear Caliper Pistons 1 Suspension: Front Suspension Type Inverted Fork Front Suspension Size (in/mm) 1.7 / 43 Front Travel (in/mm) 4.7 / 119.4 Front Adjustable Fork Pre-Load Yes Front Adjustable Rebound Damping Yes Front Central Suspension Strut No Rear Suspension Type Twin Sided Swing Arm Rear Travel (in/mm) 5.1 / 129.5 Rear Adjustable Shock / Spring Pre-Load Yes Rear Adjustable Rebound Damping Yes Number Rear Shock Absorbers 1 Rear Suspension Material Aluminum Air Adjustable No Steering: Steering Control Handlebar Technical Specifications: Length (in/mm) 81.3 / 2065 Width (in/mm) 28.3 / 718.8 Height (in/mm) 43.5 / 1104.9 Wheelbase (in/mm) 54.9 / 1394.5 Rake (degrees) 24 Trail (in/mm) 3.8 / 96.5 Turning Radius (ft) 12.8 Ground Clearance (in/mm) 5.5 / 140 Dry Weight (lbs/kg) 379 / 171.9 Wet Weight (lbs/kg) 426 / 193 Payload Capacity (lbs/kgs) 445 / 202 Fuel Capacity (gal/l) 4.9 / 18.4 Fuel Capacity Reserve (gal/l) 0.9 / 3.4 Redline RPM 15000 Engine Displacement to Weight (cc) 2.63 Horsepower To Weight (hp) 5.54 Seats: Seat Type Two-Piece Adjustable No Seat Material Vinyl Seat Location Driver and Passenger Folding No Seat Height (in/mm) 32.8 / 833.1 Number Of Seats 2 Grab Rail or Strap Standard Exterior: Frame Aluminum Body Material Plastic Hand Grip Material Rubber Foot Peg Material Aluminum Foot Peg Location Driver and Passenger Adjustable No Brake Rotor / Caliper Guard No Chain Guard Yes Drive Shaft Guard No Fork Guards No Saddle Bag Guard No Belt Guard No Hand Guards No Brush Guard No Exhaust Guard Yes Light Guard No Choke Knob Cover No Drive Shaft Cover No Swing Arm Cover No Brake Caliper Cover No Brake Disc Cover No Carburetor Cover No Front Fender Material Plastic Rear Fender Material Plastic Stand Type Kick Lower Fairing Standard Spoiler Standard Handlebars Standard Upper Fairing Standard License Plate Standard Instrumentation: Digital Instrumentation Standard Clock Standard Tachometer Standard Trip Odometer Standard Lap Timer Standard Shift Light Type Adjustable Speedometer Standard Temperature Warning Type Gauge Fuel Level Warning Type Light Pricing: Warranty (Condition) Limited Zero Price Schema 0 Identification: Generic Type (Primary) Sport Manufacturer Country Japan Manufacturer Recommend Minimum Age 16 MIC Model Segment ON-HWY Sport Bike Over 750cc Mounts: Windshield Mounts Standard Paint & Finish: Metallic No Glass: Rearview Mirrors Standard Windshield Lowers No Height Adjustable No Tinted No Height Low Storage: Underseat Storage Standard Lockable Storage Standard Helmet Locks Standard Lights: Headlight Mounts Standard Halogen Headlight (s) Standard Convenience: Handlebar Lock Standard Hope that helps.....
July 11, 200817 yr Author Firstly a big hello to all from a new member,please can somebody tell me what BHP a standard 2005 R1 produces ?.Thank you Thats great thank you,i'm going to have it put on a dyno so its good to know what it should have to start with. Bergy
July 11, 200817 yr If you put a standard bike on a dyno you will find that it produces about 15% less power than quoted. This is due to transmission losses and manufacturing tolerances. We would all have cheaper insurance if the makers told the truth.
July 11, 200817 yr Author If you put a standard bike on a dyno you will find that it produces about 15% less power than quoted. This is due to transmission losses and manufacturing tolerances. We would all have cheaper insurance if the makers told the truth. True enough so would i be right in thinking that factory quoted BHP is at the flywheel and not the back wheel ? Thank you Bergy
July 11, 200817 yr Factory quoted power is from the crankshaft and therefore pure 'engine' power. Then you start multiplying the losses straight away. Motorcycle transmissions, even the DN01 are long and lossy.
July 22, 200816 yr Had mine on a dyno at CMC on there Dyno open day, got 149.10 BHP, 173 MPH at back wheel with standard cans de-baffled & a standard Y piece de-catted. bike ran a bit rich they told me to have a PC3 fitted & custom mapped to improve BHP & running. (must say it sounds wicked on over run with all the popping/banging)
