Fazer 600 clock
Can anyone tell me what could be causing my time clock on my 2002 fazer 600 to keep resetting it's self. Have reset the damn time and again, it keeps time for so long, next time I start the bike - low and behold - reset (arggg!!)
Going quietly mad !!
Thanks
J :unsure:
  • 3 weeks later...
Best guess off the top of my head, would be a short of some sort. Have a look at the wiring diagram in the Haynes manual and see if it throws anything up. Otherwise, check for water ingress or chafing somewhere.
Also, go and ask the same question here: Fazer Owners Club - Unofficial.
HTH
DM
Is your battery in good order? (Does the engine catch on first press of the starter? Is the bike left unused for long periods, and if so do you ensure you make use of a trickle-charger?) Sounds like bike is suckin all available juice from the battery to the starter motor, and that's why the clocks are resetting. If your battery is as old as your 2002 bike, it's time for a replacement anyway as they have a limited shelf-life (even if kept on a trickle-charger).
