Posted June 26, 200816 yr right, now i found out that i am supposed to have 1 radiator, i have 2 hoses coming out om my cylinder head that are both leaking water, one of them pours out when i fill my radiator up so i cant run it because it is empty and the other comes out when the bike is started. where are these hoses supposed to go or do they connect to each other? PLEASE HELP ☺ Thanks, Nick.
June 27, 200816 yr right, now i found out that i am supposed to have 1 radiator, i have 2 hoses coming out om my cylinder head that are both leaking water, one of them pours out when i fill my radiator up so i cant run it because it is empty and the other comes out when the bike is started. where are these hoses supposed to go or do they connect to each other? PLEASE HELP ☺ Thanks, Nick. Would it be logical if the two hoses were to be fitted to the radiator?
June 27, 200816 yr Author both the radiator hoses are connected, but when i fill it up water comes out of the 2 hoses coming out of the cylinder head.
June 27, 200816 yr both the radiator hoses are connected, but when i fill it up water comes out of the 2 hoses coming out of the cylinder head. any chance that you could post a picture of your problem? this would help. adam
June 28, 200816 yr do they not go to a header tank? i dont knowmuch about these bikes, but w/c bikes usually have an expansion tank to 'dump'coolant when they are hot. maybe this is hidden somewhere they need to be reconnected to it. what size id and od are they?
June 29, 200816 yr do they not go to a header tank? i dont knowmuch about these bikes, but w/c bikes usually have an expansion tank to 'dump'coolant when they are hot. maybe this is hidden somewhere they need to be reconnected to it. what size id and od are they? how old is the DT ?
