Posted June 26, 200817 yr hello all,im new to the site.I have a dt 125,1985,lc.I have just recently got the bike and can't find the wire to go on to the temperature sender in the head.Could anyone tell me what colour it is please
June 27, 200817 yr Author also i can't get it to tick over properly.ON minuite it ticks over perfect and the next it ticks over at 2000 rpm.When it does finally come down it cuts out.Any ideas?
June 28, 200817 yr you have an intake air leak, i reckon. Could be a split in the carb rubber or the clamp not tightened properly.
June 28, 200817 yr Author you have an intake air leak, i reckon. Could be a split in the carb rubber or the clamp not tightened properly. Thanks,i have looked everywhere for a leak but there's no sign of one.When i turn the tick over screw right off it runs perfectly but just doesn't tick over.Have you heard of the throttle slide going an oval shape?Do you know where i could get one from?
June 30, 200817 yr Author Yamaha, naturally, but at some cost. Try www.wemoto.com ill try that cheers bud.
