June 24, 200817 yr I've been searching for Fork seals for my XT125X as one of the seals is is leaking oil pretty badly now. I've been searching online for replacements but I can only find ones for the 1980's model. Any recommendations on the right seal and fork oil - its a hydrolic fork with 36mm stems. Thanks
June 24, 200817 yr I've been searching for Fork seals for my XT125X as one of the seals is is leaking oil pretty badly now. I've been searching online for replacements but I can only find ones for the 1980's model. Any recommendations on the right seal and fork oil - its a hydrolic fork with 36mm stems. Thanks have u tried EBAY m8. they have loads.
June 25, 200817 yr Author have u tried EBAY m8. they have loads. Tried ebay - I can't find any seals specifically for an xt125x - if I new what size I needed or other bikes that have the same forks then i probably would be able to find loads on ebay - thanks for your suggestion.
June 25, 200817 yr Tried ebay - I can't find any seals specifically for an xt125x - if I new what size I needed or other bikes that have the same forks then i probably would be able to find loads on ebay - thanks for your suggestion. Telephone Fowlers of Bristol, or look up there website (have your frame number to hand as they usually ask for it) They are about the best firm I have found for Yamaha Parts. Usually next day delivery. Don't bother with ebay, the seals will be sub standard cheapies anyway and fail after a short time. Littlejohn..
June 25, 200817 yr Author Telephone Fowlers of Bristol, or look up there website (have your frame number to hand as they usually ask for it) They are about the best firm I have found for Yamaha Parts. Usually next day delivery. Don't bother with ebay, the seals will be sub standard cheapies anyway and fail after a short time. Littlejohn.. Thanks Littlejohn for the recommendation I'll give them a bell
