my diaphram wont stay in place
stoggy
This post is 5963 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
I just got a 77 xs400, it wont start. I am not much of a mechanic, but i figure i cant screw it up much worse then it already is. I decided to start with the carbs so took them apart, looks like they got sprayed with some kind of sealant to keep them from leaking, oh joy.
when i took them apart I stuck my finger in them and raised the round cylinder things in the main tubes, and in 1 of them I could hear a thunk in the top. I got them apart and the diaphram isn't staying in place. When I raise the round thing the rubber at the top goes up too. So I cleaned them out real good, soaking in gas and a toothbrush/air compressor. When I went to put them back together one still seems ok, but on the other the diaphram wont stay in place so i cant really put the top back on, maybe with tape or something but that's ok.
Is there anyway to repair the diaphram or do I need a new one? What could cause this problem? If i get a new one could the problem just smoke it too?
I have seen carb rebuild kits on the web but they only seem to come with needles, springs and the bowl gasket. Do they sell aftermarket diaphrams, if so should i be searching for something other then diaphram?
my is motocicle vocablary is very bad.
are you saying that the diaphragm is detached from the silde? you need a new slide - it comes with the diaphragm attached.
are you saying the diphragm won't stay in it's groove on the top of the carb? a smear of grease in the groove will hold it in place til you can get the cap on.
Yea the diaphram wouldn't stay in the grove. I was having to stretch it to get it into that slot and it would pull itself out before I could get the top back on. grease didnt work.
I fixed this though, a hair dryer and some stretching and now the carbs are working good. When I blow air past the top wide slot in the venturi tube, the cylinders raise up, and come down after wards. I also had to patch 1 of my floats but I think the carbs are good now.
Unfortunately I took the alternator cover off and oil is dripping out, when I kick it oil pours out, another problem though.
thanks.
thanks.
its over full I guess it runs out of the bottom screw hole... but they alway did on the side stand !
I dont know man I lost like a pint of oil but yea the bottom screw hole. it was on the center stand though.
jimr i think you are right. I went out and checked the oil level and now it is perfect. I kicked it a couple times and no more oil is coming out.
It will leak/drip oil out when the alternator cover is off. I will pour out if it's on the side stand. Except for setting timing etc, keep that cover on.
i hope you don't fall pregnant :rolleyes:
did you finally get it fixed and running ok ?
Heh, I hope it gets pregnant then I would have a new baby xs400. Maybe a xs250 or something?
I got it starting but it will only run on full choke, half choke, or throttle at least 1/2 open with choke off. I guess i missed something in the needles? Could mis-calibration of the needles cause this?
I installed an inline fuel filter and now I am hardly getting any fuel at all. Can't start. I am guessing take the petcock apart this weekend.
