TIMING ISSUE ON A 1991 FZ600???
I HAVE PUT INTO MY YX600 RADIAN, AN ENGINE FROM A FZ600 1991.
IT ISN'T RUNNING RIGHT, IT'S THE IGNITION TIMING. THERE A REAL LUL SPOT IN THE POWER, BETWEEN 3-4 & 6. DEPENDING ON WHAT GEAR YOUR IN.
IT'S ALL ELECTRONIC I BELIEVE, NOT A POINTS SYSTEM.
AND I BELIEVE POSSIBLY THE PROBLEM MAY BE CAUSED BY STILL USING AN E.C.U FROM THE ORIGINAL BIKE YX600 AND IT'S NOT THE RIGHT ONE FOR THE SIMILAR ENGINE WHICH HAS GONE IN. THE FZ600.
ANY ASSISTANCE IS APPRECIATED.
CALL DAVE ON 07853 702632
I CAN CALL YOU RIGHT BACK, OR ELSE LEAVE A MSG. CHEERS!!
This is really DoDo land stuff.
When you change an engine and put in a completely different one, it might be a good idea to change the engine ecu as well.
