yzf r6
hi i have an r6 just fitted a new under tray with led lights but my idicators flash rearly fast, what can i do to slow them down?
i was told i need a resister is this true? if so wot resister should i get and were do i put it?
cheers lee
You need to buy an after market flasher relay for LED lights. Where you got the indicators should stock them. They come bike manufacture specific so make sure it's for a Yam. The flasher unit is located under the tank at the rear (on 06 onwards, not sure where for earlier models), so you need to raise this slightly to get your hands in to change them over. It's an easy job, I did it on mine.
Good luck
