clutch linkage
hi all
i have a DT 125 and the clutch now doesnt work the lever moves on the lh side but nothing hapens to the clutch plates wheres the adjuster nut help !!!!!!!!!!!!!!!! or is there an adjuster wots wrong???? can any one help
hi all
Sounds like your clutch is worn. New friction plates will be the answer. In other words, strip down the clutch and renew the plates. Not a big job but you need to know what you're doing. ;)
