HI
i hope someone can help me.i have just bought a 1992 yamaha tzr 125cc and i would like to know the type of oil that goes in the engine ie under the seat and in the gear box ie near the kick start. the oil in the gear box is a clear oil if this helps.
many thanks
stew :unsure:
HI
many thanks
stew :unsure:
for the gear box oil silkolene light gear oil will do the trick and for the tank under ur seat/panel that is ur 2 stroke oil u can use semi sinthetic or fully sinthetic would recomend fully but up 2 you.
