Gear shift seal help
Hi there guys,do any of you know weather you can just pull the oil seal out from behind the gearshift lever and put one back without having to split the engine on an xj600 ?
yup. I used yamabond or use the honda version, once in grease the hole the rod goes in just incase of a burr remember just the hole the rod goes in & not the hole the seal goes in, you might chill the seal and heat the engine slightly.
