xs400 burning oil
Bike started chucking out smoke on tickover . quite a bit really. and only on one pot. Plug looks good though and
colour indicates good running engine, so whats the problem. Anyone know. Is it the rings on the piston. valve oil stem seal...
ive got a spare cylinder head in case its the seals. But will have to order some rings if this is the problem...
Any help be good... cheers...
blue smoke or black?
yea its blue, you can smell the oil and i rekon every car following me, :D
cheers
cheers
has the bike been standing for long? as the piston rings can stick and cause smokin'
if its smoky on startup and goes/lessens when warm i suspect valve guides. if its really smoky all the time especially when you shut off the throttle and bang it back on then its the rings. check the breather pipe if there is any blow from the gear box
think the bike had stood a while. so its possible the rings mite be stuck. or its scored the barrel and worn the rings out.
suppose be best to strip and investigate. is it easy enough to get the gasket and rings? you wouldnt no the prices of this gear...
cheers 4 advice...
cheers 4 advice...
should be ok, the rings should free off (ungum) by using the bike regulary.
still get gasket kits from yam (motoward/motogrid/granby's etc) I think you can still get rings, but I got mine from ebay cheap. check fro overbore sizes before ring purchase!!
nice 1.
checked pistons. I have spare top end. But will need honed and rings to...
They are stamped inside yamaha / Art / 2 / Also they measure 54mm... Will this be standard size...
nice 1.
erm.. 55mm is a 250cc piston!!! 69mm is a 400
what is your engine number?
that be a strange one. suppose its possible the spare engines the 250
*4G6-005405
cheers
*4G6-005405
cheers
that's a 250 engine
nice 1... that was lucky. would have posted on here askin why me bikes lost power :blink: . 150cc to be exact :lol:
i will see what the origionals like n take from there. or if anyone has spare barrels n pistons for sale :) ( 07779910366 ) gi me a text and i will call back... cheers...
ta for help drewpy...
try here
http://www.yamahaspares.uk.com/XS250.html
know it says 250 but there is a new 400 barrel there!!
