Posted June 15, 200816 yr Hi Does anyone know which cast rear wheels from the XS range will fit an XS 650 SE to replace the stock 16 inch rear wheel with one of a larger diameter? Cheers in advance
June 15, 200816 yr Moderator Hi Does anyone know which cast rear wheels from the XS range will fit an XS 650 SE to replace the stock 16 inch rear wheel with one of a larger diameter? Cheers in advance you'll find other xs650's had rear 19" wheels same as xs750/850/1100. xs400 and rd's had 18" front and back
