June 13, 200818 yr Hi Again Had my YBR 125 a couple of weeks now.When its warmed up changing down the gears is very tight and sometimes goes solid. Is this because its new. have done abour 300 miles. Any suggestions happily revieved. Alan
June 14, 200818 yr Hi mate, might want to get this checked, Ive had no gearbox problems with my YBR sincei got it and its done 2000 miles now. Maybe just check your letting the clutch out enough when you change down each gear. When i first got the bike i kept forgetting this as its a constant mesh gearbox, and i thought the gears had stuck, Hope this helps
