June 12, 200818 yr They work best with a standard set of headers / Exup collector. End cans that freeflow are ok, but you will need to spend some time on a dyno and fit a Dynojet kit to get any noticeable performance gains. It is easier to make it worse than better on the 750 because it is already fairly well tuned as standard. My `97 model made 3bhp more (119) than my mates `95 893 Fireblade. (116) at the back wheel, when were both completely standard.
June 12, 200818 yr Author They work best with a standard set of headers / Exup collector. End cans that freeflow are ok, but you will need to spend some time on a dyno and fit a Dynojet kit to get any noticeable performance gains. It is easier to make it worse than better on the 750 because it is already fairly well tuned as standard. My `97 model made 3bhp more (119) than my mates `95 893 Fireblade. (116) at the back wheel, when were both completely standard. would it be best for me to stick with the standerd can then?
June 12, 200818 yr If you are not trying to gain loads of power, just keep the original downpipes / collector / exup, and fit a nice looking end can. Whatever floats your boat and fits your budget. (make sure your Exup is working ok, or the thing will run like a miss firing twin!) I had an ART carbon round can on mine, looked and sounded awsome but was too load for Nurburgring. came out at 110 dBa have a look about on ebay, you could find something nice fairly cheaply. Keep the original can for MOT`s though, unless you buy a removable baffle E marked item. Yoshis always look and sound nice, They do a removeable baffle road legal TRS now. The quality cannot be beaten I`m running Twins on my R1 now, they are top notch!
June 12, 200818 yr Moderator R1evad, You may have started out with nothing, but after many years of hard work and saving....You got a truly gorgeous bike
June 15, 200817 yr Author If you are not trying to gain loads of power, just keep the original downpipes / collector / exup, and fit a nice looking end can. Whatever floats your boat and fits your budget. (make sure your Exup is working ok, or the thing will run like a miss firing twin!) I had an ART carbon round can on mine, looked and sounded awsome but was too load for Nurburgring. came out at 110 dBa have a look about on ebay, you could find something nice fairly cheaply. Keep the original can for MOT`s though, unless you buy a removable baffle E marked item. Yoshis always look and sound nice, They do a removeable baffle road legal TRS now. The quality cannot be beaten I`m running Twins on my R1 now, they are top notch! thats the nicest r1 ive ever seen u must be proud of it.
