2006 R6 LED Indicators problem
Can any one shed some light?
I have replaced my standard indicators with some LED ones and also replaced the relay unit so they don't flash to fast. My problem is that at high engine speed and with the indicators on, the fuse keeps blowing. Has any one experienced the same problem and have any info.
Cheers
There must be a short in the wiring somewhere. You can check each indicator seperately for continuity.
Thanks for the tip YODA, it turned out that the number plate light wires had rubbed on the frame through to bare wire and my installation of the indicators had moved them and allowed them to short to the frame every now and then.
Sorted
Thanks again :D
