O-ring chain fitment
road_rascal
This post is 6014 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
I recently purchased a 1982 XS400J Maxim. The original non o-ring chain is in place (530 size). Does anyone know if a 530 o-ring would work? An o-ring chain is about 1.5mm wider than the standard chain. I don't have an old chain lying around to see if it would work. Thanks.
Link to comment
Share on other sites
It will be fine as long as the width has clearence from any chain cover. You should consider changing the sprockets for new ones as well.
Link to comment
  • Recently Browsing
