Posted June 8, 200816 yr Could anyone tell me why my 250 wont bloody start???? Theres clean fuel, a healthy spark and turns over with ease...... just wont start. It was left sitting for a while but before this started and drove well. Any help, little or small would be great. Regards DH Cheers lads, i'll give it a go and let you know the out come...
June 9, 200816 yr Try having a go at starting it, then take a plug out to see if it is wet. If it is you have probably got stale juice, try emptying the tank and putting some nice fresh stuff in. If the plug is dry, you`ve probably got gummed up carbs, like DAVE.C. says. Float bowls off and liberal sprayings of aerosol carb cleaner will probably sort it, but you might have to take `em apart and clean the bits individualy.
