Yamaha dt r 125 1984 eletrical help
Hi just wondering if any one can help me with wiring up my front headlamp on the dt 125 1984 i wire it up fine and then when i start the engine and i rev it the light goes bright then it blows thanks dill
Hi Dill,
First make sure you haave he right wattage/voltage bulb,next It is either one of two things ! either you have a bad earth which is arching out ( check all earth leads are clean and tight ) or your regulator/ rectifier is toast which is more likely. Best way to check is to put a voltmeter across the battery then fire the bike up, if the voltmeter shows more than 14.6 volt when you rev it then you regulator/rectifier has had it. hope this helps you sort it out
cheers Bill
Hi where would the earth connect be thanks dill
