dill Posted June 6, 2008 Share Posted June 6, 2008 Hi just wondering if any one can help me with wiring up my front headlamp on the dt 125 1984 i wire it up fine and then when i start the engine and i rev it the light goes bright then it blows thanks dill Link to comment Share on other sites More sharing options...
billa65t Posted June 6, 2008 Share Posted June 6, 2008 Hi just wondering if any one can help me with wiring up my front headlamp on the dt 125 1984 i wire it up fine and then when i start the engine and i rev it the light goes bright then it blows thanks dill Hi Dill, First make sure you haave he right wattage/voltage bulb,next It is either one of two things ! either you have a bad earth which is arching out ( check all earth leads are clean and tight ) or your regulator/ rectifier is toast which is more likely. Best way to check is to put a voltmeter across the battery then fire the bike up, if the voltmeter shows more than 14.6 volt when you rev it then you regulator/rectifier has had it. hope this helps you sort it out cheers Bill Link to comment Share on other sites More sharing options...
dill Posted June 7, 2008 Author Share Posted June 7, 2008 Hi where would the earth connect be thanks dill Link to comment Share on other sites More sharing options...
