June 2, 200817 yr I got this from someone at work and thought I pass it on. Tips on Filling your Vehicles...This is a Message received from an oil consultant I don't know what you guys are paying for petrol... but here in Durban , we are also paying higher, up to 47.35 per litre. But my line of work is in petroleum for about 31 years now, so here are some tricks to get more of your money's worth for every litre. Here at the Marian Hill Pipeline, where I work in Durban , we deliver about 4 million litres in a 24-hour period thru the pipeline. One day is diesel; the next day is jet fuel, and petrol, LRP and Unleaded. We have 34-storage tanks here with a total capacity of 16,800,000 litres. ONLY BUY OR FILL UP YOUR CAR OR BIKE EARLY IN THE MORNING WHEN THE GROUND TEMPERATURE IS STILL COLD. Remember that all service stations have their storage tanks buried below ground. The colder the ground, the denser the fuel, when it gets warmer petrol expands, so buying in the afternoon or in the evening.... your litre is not exactly a litre. In the petroleum business, the specific gravity and the temperature of the petrol, diesel and jet fuel, ethanol and other petroleum products play an important role. A one degree rise in temperature is a big deal for this business. But the service stations do not have temperature compensation at the pumps. WHEN YOU'RE FILLING UP, DO NOT SQUEEZE THE TRIGGER OF THE NOZZLE TO A FAST MODE. If you look, you will see that the trigger has three (3) stages: low, middle, and high. In slow mode, you should be pumping on low speed, thereby minimizing the vapours that are created, while you are pumping. All hoses at the pump have a vapour return. If you are pumping on the fast rate, some of the liquid that goes to your tank becomes vapour. Those vapours are being sucked up and back into the underground storage tank so you're getting less worth for your money. ONE OF THE MOST IMPORTANT TIPS IS TO FILL UP WHEN YOUR TANK IS HALF FULL. The reason for this is, the more fuel you have in your tank, the less air occupying its empty space. Petrol evaporates faster than you can imagine. Petroleum storage tanks have an internal floating roof. This roof serves as zero clearance between the petrol and the atmosphere, so it minimizes the evaporation. Unlike service stations, here where I work, every truck that we load is temperature compensated, so that every litre is actually the exact amount. ANOTHER REMINDER, WHEN YOU STOP TO BUY AND THERE IS A FUEL TRUCK PUMPING INTO THE STORAGE TANKS, DO NOT FILL UP. - most likely the petrol/diesel is being stirred up as the fuel is being delivered, and you might pick up some of the dirt that normally settles on the bottom. Hope, this will help you get the maximum value for your money. DO SHARE THESE TIPS WITH OTHERS! LETS SHARE INFORMATION AND BENEFIT ALL, FOR THE BETTER OF MANKIND.
June 2, 200817 yr Hi mate, thanks for the info. But just how much difference are we talking about here? For example: If I pump 10 L on the worst time possible with a empty tank, how much fuel might be lost? I find your info very interesting and I will keep it in mind, but how much can you possibly gain? Cheers mate.
June 2, 200817 yr Author Hi mate, thanks for the info. But just how much difference are we talking about here? For example: If I pump 10 L on the worst time possible with a empty tank, how much fuel might be lost? I find your info very interesting and I will keep it in mind, but how much can you possibly gain? Cheers mate. Sorry but not sure as I got it as you see it, just one of those e-mails that go around, but at these petrol prices every little bit counts
