May 30, 200817 yr i'm running pods and i have a filter on the breather case outlet. i just split the cases to change out some of the gears in the trans. went for a ride and everything runs smooth. idle great,clutch perfect, pulls like it always did and should. little leak from the clutch cover but i have a basket to fix that. smoke is coming from the breather filter. never did that before. any ideas?
June 1, 200817 yr Moderator i'm running pods and i have a filter on the breather case outlet. i just split the cases to change out some of the gears in the trans. went for a ride and everything runs smooth. idle great,clutch perfect, pulls like it always did and should. little leak from the clutch cover but i have a basket to fix that. smoke is coming from the breather filter. never did that before. any ideas? is it just slight oil vapour or is it puffing out like a chimney?
June 1, 200817 yr Author figured it out, a little to much oil in the engine. hitting the back of the pistons.
