fj1200
hi my fj1200 is a bit flat at one and a half thousand revs up to two thou then it takes off booked it in to get carbs balanced has anyone else had this problem its only at low speeds low revs starts fine runs fine above 2000 revs?
Deffo sounds like the carbs, probably the mixture incorrect. I have never had this problem but I balance and check mixture every 4,000 miles.
Adam.
Adam.
cheers m8 booked in thur £15 balance of carbs let you know if it solves it
do u use any kind of redx treatment ?
I don,t use any addativs, but every third fuel fill up I use the high octane stuff i find that this gives me carbs & valves a good clean.
Were in the country are you situated ?
Adam.
Adam.
peterlee co durham the balancing of the carbs did not solve the problem
