May 24, 200818 yr Alright, first of all, thanks for taking a look at this little problem! Since I got it a month ago it has never fired for me on the right cylinder. I have the parts manual and a service manual from another xs400 of the same year so feel free to reference them. I'm putting the bike back together and here's what I've done to try and fix or diagnose: -Took the carb apart and cleaned it, checked the pilot screws and one was all the way in so I backed it out 2 1/2 turns as per the service manual. -Put in brand new spark plugs, caps, and spark wires on both sides. I have checked and there is spark on the both sides. -Checked what was coming out of the exhaust of that cylinder and it's gassy air. -After a few minutes of reluctant idling the left exhaust is hot hot hot, and the right is not not not. So there's at least some gas - I don't know if it's the right amount - and there's some spark, but it feels like it's not firing at all. I have a worse condition carb I can swap in that was sold as "working good." I'm about to try that. Thanks again for looking and for sharing any thoughts. Aaron
May 25, 200818 yr Two things come to mind, you could try turning the mixture screw out another turn or so, my xj would not even fire on 2.5 turns out(as per manual), or the carbs need a good cleaning especially the starter jets.
May 25, 200818 yr Author Two things come to mind, you could try turning the mixture screw out another turn or so, my xj would not even fire on 2.5 turns out(as per manual), or the carbs need a good cleaning especially the starter jets. I will try that today! I wasn't sure how much those turns affected firing... looks like I'm learning already. Thank you very much for the suggestion.
June 8, 200817 yr had the same problem . PO had left the choke on and backed off the idle speed screw . as soon as I set idle I turned the choke on full and bang pop, then it started now its runs great . Idle speed should be 1200 rpms warmed up. yes clean the carbs
