XJ600 Engine removal
Hi all,
I've been trying to remove the engine on my Divvy today. All went well until I came to removing the bottom mounting nut. It doesn't explain it well in my manual but I assume it is a long bolt that threads through the bottom part of the engine mounting with a nut on the right han side. The nut came off easily enough but do you think I can shift the rod/bolt. If I've assumed correctly the head of the bolt is missing on my bike for some reason. Could have been sheared off I guess. If this is the case has anyone got a suggestion on how I can get it out.
Cheers,
Spuggy
