d.mac rx Posted May 20, 2008 Share Posted May 20, 2008 on the kickstart side of the crank case the is a small circular window below the kick start the is no oil in there should it be full and if so what oil do i need. also if i ride the bike around for a while there is engine oil ontop of the case could it be just a new gasket is needed. and 1 last q there is a rattle again on that side of the engine and builds with the revs any1 had this problem thanks alot Dom. Link to comment Share on other sites More sharing options...
syks Posted May 20, 2008 Share Posted May 20, 2008 on the kickstart side of the crank case the is a small circular window below the kick start the is no oil in there should it be full and if so what oil do i need. also if i ride the bike around for a while there is engine oil ontop of the case could it be just a new gasket is needed. and 1 last q there is a rattle again on that side of the engine and builds with the revs any1 had this problem thanks alot Dom. There should be gear box oil in there,im no expert but the rattle your hearing could be signs that your bike needs a rebuild,it could be the top or bottom end or if your unlucky both.Im sure someone else with a bit more knowlage on the mechanical side of bikes will come along and help. Link to comment Share on other sites More sharing options...
d.mac rx Posted May 24, 2008 Author Share Posted May 24, 2008 bump really do need to no what oil it needs in the gearbox/kickstart side of the bike thanks Link to comment Share on other sites More sharing options...
d.mac rx Posted May 30, 2008 Author Share Posted May 30, 2008 does any body out there no please Link to comment Share on other sites More sharing options...
Tuggwell Posted May 30, 2008 Share Posted May 30, 2008 10w 30 motor oil Link to comment Share on other sites More sharing options...
d.mac rx Posted June 5, 2008 Author Share Posted June 5, 2008 10w 30 motor oil cheaz mate i have loads of castrol 10 40w engine oil will that work thanks Link to comment Share on other sites More sharing options...
