Anyone know the correct codes for Marlboro orange & white paints. ?
Update on TZR600, - TZR250 engine has been out to replace knackered left cylinder +piston, while it was out I offered up the XT600 lump. it will fit well but I will need to mod the lower frame mount that normally holds the lower frame brace.
I will need to fab & weld a wider mount while retaining the same hole axis, I will incorporate this with the original suspension pivot point, this should give me a good strong lower engine mount & allow sprocket alignment.
I'm quite tempted to buy another frame to do the mods on, this will leave the 250 in one piece for a bit longer while I make the various bits.
TZR250 engine back in now & almost ready for road use,sounding good & looking like a good'un, so I might end up with two bikes from this project
News on the name, we have a winner, so future posts will be titled XTR600
I've found a BASF listing:
name: 3024 RED 923RAL OOT Florescente LT.1
code: AD23-3024 1613
yamaha colour: 00JV MBR (marlboro red)
i'm still digging.............
