YBR125 headlight upgrade
john mccammon
This post is 4122 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
im considering changing the standard 35/35w bulb for 4 bulbed headlight with 2 35x35w that turn on when i use the full beam switch and 2 55x55w bulbs as the main headlights
im looking for a style close to Rage Enduro Fairing - White / Black
http://www.intobikes.co.uk/products/001376/Bike-It-Rage-Enduro-Headlight-Fairing?highlight=27533
would it be possible and how would i go about it?
Before you attempt this, remember that it may not be road legal and it may suck more power than the YBR can produce which will leave you stranded somewhere.
You will also need to fit a couple of relays and some decent wire for the high drain part of the circuit. If you don't you will possibly melt part of the loom somewhere and start a fire.
