FZ6 Fazer vibration
Howie69
This post is 6078 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
You need to be more objective about the vibration.
Does it always happen on the same road or route?
Is it with the same pasenger?
Have you checked the balence of your wheels?
Have you forgotten to fully service your front forks?
Have your steering head bearings failed?
Is the rear wheel in line?
Is the front disc warped?
Are you using more rpm than normal?
Are the rear bearings worn?
Are the swing arm bearings worn?
Have you fully checked your tires (tyres) for wear or blisters?
All these and other questions YOU will have to answer.
