Wirth progressive springs ?
DraxDave
This post is 757 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hi All, I am loving my 2003 TDM 900, travelled over 2,000 miles since december. The suspension is a bit lacking, bit it is a 19 year old bike, so time for some upgrades I guess. I've tweaked the pre-load and rebound which has helped a bit; bit less sure about the fork brace though !
The next step is progressive fork springs, I'm looking at a set from Wirth DE, anyone tried them ? Cheers dave
Progressive springs might help, but you'd be better off going to a specialist and getting springs with the correct rate for your bike/weight
  • Thanks 1
As long as you set the static sag to around 20 to 25mm you will be fine and there will be an improvement.
You cannot just fit them.
i got my TDM setup by Kais suspension. they did an amazing job and the bike feels so planted
