Battery charging issue - new biker looking for help
fairlo
This post is 1040 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hello,
I am very new to biking and have have just bought my first bike a 2008 Yamaha YBR125.
Twice now it has let me down with a flat battery giving code 43 and refusing to start via electronic start. Changing the battery over night fixes the issue.
So far I have replaced the battery with a new one but the following symptoms still occur and I am hoping someone might be able to help so I don't just keep buying new parts.
With the ignition off there is 12.3v across the battery terminals. Running the bike on idle and the voltage starts to drop down to 12.2v then 12.1v and after about 10 mins it's down to 11.8v. revving the bike makes no difference to the voltage at the battery terminals. I am guessing this is why the battery keeps going flat as if I understand correctly the bike while running is using more voltage than its giving to the battery and therefore the battery gets flat and the bike stops running.
Does anyone have an experience or ideas where I should go next to try an resolve the issue.
Thanks in advance for the help
Edited by fairlo
First question is:
WHEN exactly did you buy it?
Second question is:
Was it private or dealership?
If you've literally just bought this bike, then it's not your problem (unless you knowingly bought it with electrical problems).
If it doesn't get you around, then it is 'unfit for purpose' and a FULL refund is warranted...
There are MANY more bikes out there to chose from, there's no reason to take on a problem when you don't need to.
P.S.
Four LONG flashes, three SHORT flashes?
Fault Code 43
Fuel system voltage (monitoring voltage)
The ECU is unable to monitor the battery voltage (an open or short circuit in the line to the ECU).
