tvuorisa Posted May 16, 2021 Share Posted May 16, 2021 New user... old bike, maybe known problems... My son has a 2012 WR125X. We were supposed to go for a weekend trip. After about 100km (60miles) it started to misfire... and around 200km (125miles) engine just stopped. It gives a spark, with a new plug and gasoline is smelling while starting. Battery is ”new”. It has 183cc Malossi cylinder, Malossi Force Master2, Gianelli’s exhaust. If I understand correctly, fault code is for Ignition coil. Local Yamaha service is saying it is not that, but can’t figure out, what it can be? Any ideas? Thanks for your thoughts in advance! Link to comment Share on other sites More sharing options...
Moderator Snakebite68 Posted May 16, 2021 Moderator Share Posted May 16, 2021 What exactly is the fault code you're seeing? Link to comment Share on other sites More sharing options...
tvuorisa Posted May 16, 2021 Author Share Posted May 16, 2021 3 long flash, 3 short flash ... Assuming it is 33. Link to comment Share on other sites More sharing options...
