Ybr 125cc 2009 code19
Bucko87
This post is 1112 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hi I have the code 19 on my ybr125 2009 so I have changed the ignition and the ecu and the coil and the spark plug i have checked all the wiers and all are ok and I'm still getting the code 19 can someone please help me with this also I bypass from the + side of the battery to the horn connector and the bike starts but when I go to put it in gear it cut out
Fault code 19 - No signal from ignition to ecu
Have you checked the kickstand kill switch?
