Posted June 15, 20205 yr Hi! Im new on this site, so I hope this is right place. I need a little bit of help. I bought soft saddle bags for my Yamaha YZF600R. Richa Twin: https://www.motonet.fi/fi/tuote/3826...ut-mustaharmaa and I have a problem. How do it assemble those to my bike that way that those stay on and dont fly away on higher speed? Also I would like to assemble bags comfortable enough for a passenger too. Is that even possible? Hope somebody can help me...
June 15, 20205 yr Moderator  have a soft set on my fz600 . mine have a strap and this is fitted under the seat to get trapped there. this holds them in place  you can put some bungie cords to stop the bottom flapping around
June 16, 20205 yr Author Thanks for your reply.  My bags came with 2 straps and 2 bungie cords. I tried to place straps under the seat, but then the seat don´t get locked correctly. Also I´m little worried if I put those to my bike, my tail fairings could get scratches. Bungie cords are all right and I can put those under the tail. And other problem is that if I put the bags on to my bike, theres no leg room for a passenger, but I guess I´m using bags only when driving alone or with other bikers. Edited June 16, 20205 yr by tjoutsin added some text
June 16, 20205 yr Moderator Quite often its a choice between the 2, pillion or luggage. Either because of space, or the tail is built down to the minimum to be light. Get the pillion to wear a backpack. Â
June 16, 20204 yr Buy a cheap role of that anti slip matting (often used for keeping a sat nav from rolling on a car dash). Put a piece of that between pannier and bike contact points to help reduce marking.If the straps on the pannier bags don’t fit under your pillion seat then I would just get creative with my own straps to make sure they are secure.
