Error code 19
Kizzey
This post is 1407 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
If you get an error code 19 on your bike ie the bike runs then stops nearly throwing you off then starts then stops then doesn't start this is usually due to error code 19 common fault with yamaha  across the board (it's the side stand switch you can either clean the connections and put it back on or you can do what we did and remove it completely this will ensure you ever get an error 19 again either that or buy a new side stand switch over time they degrade I hope this has been useful to everyone
Strange first post, will there be more nuggets of info, maybe the whole code series. A motorcycle whodunnit of error codes..?
