XJ900f Engine Builder
XJ900fTrike
This post is 1423 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
As we all know getting brand new pistons for the xj900f can be very hard. But over the years with trail and error I have found some available now..
You will find the xj900f standard bore is 69mm
The Suzki 850 over sized is 70mm   and the dome is 1mm taller..
I have designed and built my own Trike and the 1mm taller dome makes more hp the faster you go...
The higher speeds means you will need racing oil...
Please be careful.
Thanks
good info, did you have to machine pockets for the valves?
