Thunderace power issue
StevieG
This post is 1254 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hi All . I Have a thunderace sitting In my shed that I brought a number of tears back , the exhaust system had been replaced by the previous owner and the Exup valve removed . The issue is that it accelerates hard up to about 7000 rpm then will not rev past that  ..Any ideas where to start ?
Thanks
  • 4 weeks later...
Hi there , sorry cleaned carbs ,flushed tank etc , new plugs as well still just stops revving at that point , I'm assuming that's the same Rev area the exup valve would start to do its thing so wondering if there is something sensor wise stopping it ? , it's not a flat spot you can get past it just dies there. Cheers
  • 7 months later...
Did you get this issue sorted?
The exup was for low rev power, it shouldn't cause this.
