Need advice on Yamaha dt125 re brakes
This post is 1748 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hi I have recently noticed  that both brake callipers have moment in them. It's not where the bracket is but where the actual calliper sits. The whole calliper has Tiny amount of movement in it. It almost seems like it is meant to move because it has tiny spongy plastic gator on the brake calliper mount, just wanted to make sure tho. So if someone could advise me that would be a great help as I aM worried that it will brake it if I continue to ride it
many thanks
dtstrider
They are sliding pins. If it didn't move your brakes would not work as efficiently.
