Help and advice needed
RagnarLothbrok
This post is 1978 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hi everyone! I’m new here and am looking for some help. I’ve got a Yamaha xvs 1100 dragstar and appear to have a tiny oil leak from the rear cylinder that appears to be about the head gasket. How hard is this to strip down and repair and is it possible to repair it myself without needing to have the head skimmed? Or is this possibly a ‘vibration’ issue where the bolts just need re torqued? Please help
I would qualify the above with check the head bolts are tight with a torque wrench rather than nip them up. Don't want to snap or weaken a stud. Head bolts don't vibrate loose unless they were not done up properly in the first place.
If its a truly 'tiny' oil leak don't worry about it.
Would we be advocating loosening off all bolts prior to re-torquing them
