XT600 1998 Intake
FinXT600
This post is 2055 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hi! I ordered intake manifolds for xt600 1998, 3tb. I Got different which I had. Original intake has black airbox connected to intake manifolds and I got manifolds without connections to air box. Question is, what is this air box? Can I live without it? Why they add this air box to 1998-1999 models?
thanks!
The airbox is the [usually plastic] housing that contains the airfilter. Typically it'll have an access panel to get to the filter or can be separated to get to the filter. It has two orifices [oo-er] one that lets free air in and one that connects to the carburettor or throttle body.
edit: Hang on the manifold shouldnt connect directly to the airbox. there should be a carb in between.
Here:
https://www.fowlersparts.co.uk/parts/4155904/xt600e-4pt7-1998-050-a/intake
From engine: manifolds, then twin carbs, then tubes, then airbox.
Edited by pilninggas
 No. I know airfiltter box. This box (size of cigarette box) is connected to intake manifolds. Why? Can I forget it and put intakes without that box?
That part is number 8 on previous message attach. Please, take a look, number 8
Edited by FinXT600
oh yeah, looks like an intake resonance box or balancer.
I'd try running it with the connectors blocked off. If that doesnt work well maybe a link pipe?
You could make something to imitate it.
