crank bearing slightly loose
nigel smith
This post is 2209 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
hi all
I am building up an Aprilia moped engine that has suffered a seized main bearing, it has spun the bearing in the case.
the new bearing is a good fit but not as tight as it should be. can anyone recommend anything to fix the bearing in place?
cheers
nige
Locktite, this stuff:- https://simplybearings.co.uk/shop/product_info.php?products_id=340252&vat_inc=true  or something along those lines.
Best of luck to the next guy trying to get it out mind.
